2005 CVO Fatboy: 110 kit, ported 2005 CVO heads w/1.94 valves 54mm TB, 1.75 intake runners, 10.83 compression hemi heads, forged pistons, 257 cam (252/260 .569 lift), has modified V&H Pro pipe 2 into 1s, low restriction a/c. Currently makes 127 rwhp @ 5700 rpm and stays flat till 6200 rpm. I'm looking for a higher peak HP, perhaps climbing from that 5700 point. I'm thinking that the V&Hs with their 1 5/8" primaries are the problem. Every time I mod the muffler section the HP climbs some(I have a flow bench). Anyone replace V&Hs with Fatcats (3 step primaries) and have dyno sheets? I have plenty of bottom end and midrange now and less bottom end would make it hook up better anyway... I am also running a T-Max auto tuner, so I can make hardware changes as often as I do without dyno trips. I will change probably to a 256/256 cam with something like .620 lift after I figure out the pipes too. TIMINATOR
