sad day when you check your compression at less then 3000 miles when the motor starts to knock! 100/90 psi.then take down to find the worst fit piston to wall I have ever seen 20+ years! and the crank runout @ .013.I sure the crank got hurt limping it back.but i'm sure 100% due to ring seal.this really is **** work! what ever happened to someone taking pride in there work? expensive short ride! well it will be right this time......
