marking its spot: leaking primary
21K views 77 replies 14 participants last post by  havinabubble
#1 · (Edited)
I've never suffered with this problem on ANY of my Harleys until now
primary has been on and off more times than a whores drawers (see my other threads).
but last time on, new gasket was fitted
'86 FXR 5speed evo
I finally got the bike back on the road and so its been plenty of shakedown mileage of late, to see how things are behaving.
  1. leaking jackshaft seal [SOLVED]
  2. fresh chain lube dripping everywhere [SOLVED]
BUT every time I park up I now get a little drip/patch under the bottom of the primary, approx the oil screw (the lowest point)
WHY?!
Have I not aligned the gasket right? (looks a tiny bit out towards the leak in the below pic)
I've tried to take clear closeups, so that anyone can throw their 50pence in as to why I cant stop this bloody leak!
doesnt seem to be coming from ANYWHERE else except the bottom of the primary
tips for putting the primary gasket on the best way and which bolt goes where (I believe there are two different lengths of primary cover bolts...have I got them wrong perhaps?)
?anyone?
*pics taken just after a run out. The bike is level on a jack
#2 ·
what type of gasket did you use? do not use sealant on the gasket, if you did, that could be your issue
#3 ·
no sealant.
normally I have a Silicone-Beaded type (grey with red line)
but this was a regular looking gasket, think it might even have been a JAMES.
Most notable thing was the large triangle area (old one didn't have that)
I'm sure its just the way I've aligned it, if anything.
I'll drain and pull the cover and then can tell more
#4 ·
R u 100% sure its primary fluid and not tranny fluid. I think no matter where the leak is, it always ends up to the bottom of the primary like that. I chased a oil leak thinking it was the primary but it turned out it was the transmission quad and main seal. Change out the primary fluid to atf so he can make sure that's the oil that is leaking since it will be red
#6 ·
There are several places that leak, all appear to be the primary, but some aren't.... starting at the front...
Engine o-ring
Outer bolts at the front of primary, these need silicone on the bolt shanks
Generator plug
Leak where shifter shaft passes through primary
Shifter shaft seal
Small seal on 5th gear
Large seal on 5th gear
Seepage through 5th gear and sprocket shaft spacer (many have a quad seal there)
Inner primary mainshaft seal
Hairline Crack, or porosity of primary housing
Crack at drain plug, drain plug under/over tightened no sealer used on drain plug
Never use sealer on beaded gaskets, or afm gaskets
Derby gasket, some older bikes, with the o-ring and sealing washers, will not seal, with the new gasket
Inspection cover gasket
Using the wrong outer primary gasket, even though all the bolt holes align
Depending on how the bike sits, all of these appear to leak at the rear in the drain plug area, or at the front near the comp sprocket area, it's gravity and wind currents moving the leaked oil to the lowest spot, before it drips...
Sometimes I use q-tips to locate leaks..
#7 ·
:unsure: for once I'm hoping you are wrong on 13counts, at least, TT!
whatever it is is minor.
since I got the chain lube drip out the way, and the jackshaft leak sealed. It appears golden in colour and seems to be towards the bottom of the primary and no higher.
I know I don't have the primary over filled and having changed the gasket for a new one I figured it would stop.
I'm aware that some of the primary cover bolts are different lengths, and I wonder if one is just not pulling in far enough, but I cannot find a diagram for this. I'm gonna try measuring the hole depths that I read here on the forums.
Also gonna try PTFE (Teflon) tape on the oil drain plug
All are done up to correct torque, and I've even tweaked a little more to be sure, but it hasnt stopped it.
Only seems to occur after a run, so figure its pressurising or warming up and leaking
I'll work me way through this list and see what I can identify.
Just so sick of taking the primary off and on, and I know every gasket and seal has now been replaced.
cheers
#12 ·
If that is the old style paper gasket, it may take a few heat cycles to seal up, the gaskets work well, but they have to absorb some oil before they stop leaking and may need a retorquing of screws. That was the mistake a lot of people made when that style of gasket was more common and people would smear sealant on them and basically ruin them and cause them to never seal correctly
#14 ·
I hope im weong on most of that list as well, lol...
Since it only drips after a ride, that points to something above the static oil level....this point to:::
Starter jackshaft seal
Mainshaft seal at the back of the primary,, did the inner race have a ring around it? If so you should polish that off with sandpaper for a consistent surface
Quad seal on 5th gear behind the sprocket shaft spacer
As already said splines on 5th gear having oil seepage.. if this is the source, you can pack the splines with black rtv then I stall the nut and torque befor it sets up..
Inner primary bolts wicking oil down their shafts and presenting as leak, I use loctite on the threads and rtv on the bolt shanks..
Rtv around the stator plug these leak and seep
Outer seal rhea small one on the transmission mainshaft.
The outer primary gasket so.erimes seeps as already said
Some early derby covers, gaskets, and outer primary combinations leak when using the flat derby gasket
Use the sealing washers on the derby cover screws
Atf is a good idea, it the leak is red, you found the source, if it's not you eleminated one source.
Sometimes harley castings are porous,, (I had a leaky rocker box on a new shovel, turned out to be a porous casting)
Definitely use pipe dope or Teflon tape on the pipe thread drain plug
Just a few things to look for, with cures
#17 ·
again, cheers for more pointers TT
I'm running 2 derby seals at the mo, the o-ring AND the Harley recommended full size one (that thing leaked like a mofo when I put it in on its own).
Certain its not the derby, or coming down the front of the primary, but I gotta figure it out. Things like this drive me nuts!
pretty certain its not the jackshaft seal either...having pushed that all the way home to stop the previous obvious leak.
I'll jack the back of the bike up higher so I can see right into the drive area.
i'm putting my money on the outer primary, as I've not tried to adjust this new one yet. But I'll do that when I put the ATF in.
still cannot find a diagram showing the location of the various length outer primary bolts... ?anyone?
#15 ·
Those quad seals can be a pain in the ass, easy to cut one on the splines and a little bit of a bitch to make sure they are seated correctly
#16 ·
IF the quad seal was leaking, where would I be seeing signs of oil (when looking up from underneath?)
I've not taken anything apart yet.
I'm gonna try the drain and ATF fluid recommendation, cause that will show me Primary vs Tranny leak much quicker.
I know I put the seal in, but you are right, it could have got pinched or cut during my other issues
cheers
#20 ·
Thing is, you have to wipe everything down to find the culprit unless you have visibly different oil in the primary and transmission, because the front belt sprocket throws it all around. Basicly, if oil is coming from in front of the pulley, it is the rear primary seal, from directly in back of the pulley and actually wetting the back ( facing the transmission) of the pulley, it's the quad seal, closer to the transmission in the same line, it is the transmission main seal, slightly in front (forward) of this area on the transmission would be the shifter shaft seal.
#23 ·
...so a few test rides later :chopper:
Automatic Transmission fluid hasn't changed a thing, you still have to change gear manually! :redrolf: but it has now shown that it's the trans leaking.
seems to be the main seal behind drive sprocket from what I can see. will pull apart again and re-seat, like i did with the jack shaft.
Also an odd discovery, while measuring depths of the primary bolt holes (as you do) I discover that this hole was 6inch deep!!!!!
...that was until I realised it goes right THROUGH the inner primary! :wacko:
Should that be? has someone drilled it out by mistake or should there be a rubber bung or similar at the back of it?
#28 ·
so lets talk quad seal etc.
switched the primary to ATF. but my drips have turned to puddles, and they weren't red!
Spotted a leak down the back of the drive sprocket, clearly coming from the mainshaft on the trans.
In turn the sprocket is flinging it all over the housings
with the primary removed the leak seams to be pretty substantial from the inner diameter of the transmission seal.
IF I move that spacer-sprocket it absolutely gushes out! (appreciate I haven't drained the trans yet) ...should it do that?
Where is this quad seal and whats it look like?
I've seen various forum pics and it appears to be a large diameter ring, others show it as o-rings, and the FSM says its a ball bearing? (32)
so looking at the good book, Trans Housing, its not quite the same as I'm chain and this shows belt...but:
32 quad seal, ball bearing
34 oil seal
42 spacer sprocket
43 belt drive sprocket
...going to order a new spacer sprocket (42) today as I'm told they wear (and mine doesn't look to bright)
?anyone?
#29 · (Edited)
#31 · (Edited)
thanksDan89FLSTC & Nitram
I've just ordered a KIT from my VERY reliable indy and he gave the following part number for my year, model and being a chain:
L84-94BT 5SP M-SHFT SEAL - DS194476
I've already replaced the mainshaft seal, but it wont hurt to have a spare...but note the size of the O-ring
why is this called a QUAD seal? surely quad means four?
when ordering the spacer I note on his diagram the following:
73 - so thats not the quad seal you are all referring to?
46 the spacer-sprocket I've ordered.
but what is 36?? and can it be fitted from OUTSIDE the trans?
also will 46 spacer-sprocket be different lengths for chain OR belt drive?
#34 ·
Quad because it has four seal surfaces. But basically a fancy square cut oring. It seal the inner taper on the sprocket spacer to the outer face/shaft of 5th gear. It's a real iffy seal that was an after thought on the design. If every thing is just right, and it all goes togeather just right they work. If they don't work, you don't find out about it until the scooter is all back together and on the road. I don't use them any more.
#33 ·
good to know, thanks
so you pushed it deep I presume?
having watched the earlier video (filmed in an earthquake simulator)the seal appears to go INTO the end of the chamfered sprocket spacer and that slips over the mainshaft, into the mainseal it would appear.
I'm pretty certain I fitted one... but obviously I'll go back over all this
also the video mentions the fact the spacer gets worn by the main seal... which is perhaps where my problem lies
cant answer all your questions but
i believe 36 is the quad seal. it seals between the 5th gear shaft & the countershaft. when i replaced it, i picked out the old one & used a modified PVC pipe to install the new one.
#39 ·
73 is the sprocket nut lock plate, slip it over the torqued nut then insert 2 10/32 screws with blue loctite to keep the nut from loosening..
36 is the small oil seal for 5th gear it goes over the mainshaft... it must be installed from the outside and may be put in while the transmission mainshaft is still installed.....
I use rtv on the outboard end of the spacer, before the pully is installed, and pack a little into the splines about 2-3mm in and then assemble it all before the rtv dries..
Either way should work
#40 ·
...Once more unto the breach +SMSH+
primary off and here's up close and personal (spacer removed).
Note the welling up (6 o'clock on the main shaft seal)
so I drove the mainshaft seal back a little further...few mm...and gave the quad seal grove a good clean. new quad seal pushed all the way home
I turned to the replacement spacer.
Unfortunately what my indy supplied was not what is on the bike (half the height and a tiny chamfer in comparison)
ran some scotch bright over it and placed it carefully back into place.
currently I'm bolting back up and oiling... will see how this behaves
#50 · (Edited)
Mine wasn't going to buff out. I had a pic but it's on my home laptop.
Here's the pic. You can actually feel the groove with your finger.
Amazing how a rubber seal lip can cut a groove in a steel spacer isn't it..
That's no lie. Almost defies logic.
I'll test that theory this evening.
