Hi guys, some of you may remember my initial grief with this motor..
It continues...
So, had motor for just over a year. 7,000 miles. Broke in as per Jims instructions. Not counting the first oil change at 50 miles, or the second at 250 miles or the third at 500 miles it has had the oil changed every 1500 miles. After breakin switched to Amsoil. Have the Dakota Digital oil temp gauge in the Baker Plus one pan and never seen higher than 235. ( I havn't overheated the motor).
Motor was always noisy. Started to use a quart of oil every 500-600 miles... Decided to change the cams, ordered some Woods lifters at same time. First sign of internal grief was when pulling the lifters... roller axles had an average of about 1/8" play!! They were a time bomb waiting to grenade!! So much for the new style Jims lifters.
I took bike up to Dean at his new shop, Vancouver Island Performance, and asked him to check things out for me...Checked oil pump... it's severely scored. Pulled heads, rear exh valve seal is toast. Pulled cylinders, rings are shot, pistons show some scuffing, crank was welded by Jims, however, have 4 thou runout. Get the rods in the right position and you can just feel an up and down looseness as well.
Bottom line is this motor needs complete rebuild. Yes, I have rode it. Rode it hard. Never abused, never overreved it, always let it warm up before getting on it, in short didn't do anything wrong. (Apart from buying a Jims motor).
Jims "warranty" is very simple. Pull the motor, crate it up and send it to them, they will decide if it's warranty or not, fix it (or not), and you pay the shipping. Based on my first experience with them about warranty, add to that I am out of warranty by a couple of months, not worth the effort.
So..... The rebuild begins... As I am up here in the North West I am having Dean send heads and cylinders to Baisley, re configure rocker arm geometry, port match the intake, bore cylinders, etc etc. Decided to go with the T Man 662-2 cams with the 4deg key and Tmans 20deg dome pistons so Baisley will reshape heads to match. Crank going to Darkhorse for full treatment including dynamic balance.
A blatent plug for VIP.... Dean is bending over backwards to help me out with this nightmare. Great communication, great knowledge.
He is a class act and I am sure you will start to hear more and more about him and his builds/tunes. ( He just installed a brand new loaded dyno in his new shop as well)..
question.....
I've read lots of positive stuff about the "Singh Grooves" ??
I can not find anything bad, anywhere.. Anybody have a direct
experience??
It continues...
question.....
experience??
