Hoping to get some opinions to steer me one way or the other. I currently have a Rivera Pro-Clutch in my 89 FXR and after 100 or so miles it starts to become painful to pull the clutch in so I need to address it since 100 miles is a short ride to me. I should note I have limited extension in my left hand which only allows me to pull the clutch with my 2 fingers, I have the exact same reduced diameter grips and short reach levers on 2 other bikes so that parts addressed.
the Muller Power Clutch seems like the easy and less expensive option. under $250 and less work. My hesitation with going with the Muller is it took me many tries to get the clutch adjustment correct on the Pro-Clutch where it wouldn't drag in gear. As is I'm only backed out 3/8 turn on the adjuster and barely an 1/8" of slack on the cable. With even less throw going to the Muller, I'm afraid I'll fry the throwout bearing adjusting too tight in order to get good realease. BTW I've checked the diaphragm spring to see if it needs shims and its good. I think I just suck at adjusting it.
Hydraulic seems almost easier for me then going back and forth with clutch adjustments. Downside is it would cost about $600 and I'd have to ditch the brake/clutch levers that I know work for me. The only levers that seem like they could work for the trike clutch master I have are Oberons which are expensive. Alternatively I could use a clutch master from a newer touring bike, however I think they're too bulky looking.
Anyone want to talk me into one direction or the other?
