Anyone know if Brembo makes a dual-disc four-piston caliper set-up for an FXR? Part #, pics, price, etc.
I have a 2000+ front end and 2 brake calipers to put on my 85 fxr, i just need to buy a right side fork lower. Will 11.5" rotors work with my calipers? View attachment 271827
Do you guys know if the fork lowers from a 2000+ dyna and sportster are the same?Yes.
Hi BobDo you guys know if the fork lowers from a 2000+ dyna and sportster are the same?
I have 2000+ sportster front end to put on my fxr but its only single disc, i have 2 4pot calipers and a 11/16 M cylinder and 2" longer tubes, so just need a right side lower with caliper brackets to complete the package
Looking on Ronnies parts finder the fork sliders of the dyna and sporty have different parts numbers. Its does'nt seem they have right side fork lowers with caliper brackets for the sporty.
Dont want to order a dyna lower then find out it has diff axle dia or some other differences.
Thanks in advance,
Bob
Thanks in advance,
Bob
Thanks fellas
Nice looking calipers, but I already got the 4 pot calipers and front end for them.Wilwood GP310 calipers bolt right up to your 99 down fork legs, they are American made and work great.
You called it. The adapter plates I got bolted the Nissen calipers right onto the 88-99 39mm forks. The same year Axle fit right into my 87 wheel with 11.5" rotors. Now I'll have to plumb in the 11/16" master cylinder with banjo fittings and brake lines. You ARE the man!Gregg55_99 posted: "I have a set of the 2000+ black Nissen (I think) four pot touring calipers. I have a set of fork adapters. I have a set of 1988 39mm forks. I have an 11/16" master cylinder. Can I re-use my 35mm front axle and wheel AND 11.5" rotors." According to all you have written you should be good to go with your caliper adapters. In 2000 when H-D switched to the new four pot Nissan calipers they changed the bolt hole pattern on the sliders of Sporties, Dynas and FXR's so the new calipers don't mount up on the old fork sliders. I'm pretty sure H-D used the same sized 3/4" front axle on both Sporties, FXR's and Dynas on both 35 mm forks and 39 mm forks. So, your engineering change should be a simple bolt together op! And all the front four pot calipers were interchangeable on the all the Sporties, Dynas, Softtails and baggers. Call me at 270-234-6211 or email me at kdkerr2@msn.com if you have any problems. Please post a pic of your bike when you get your changeover completed.
