Hey guys trying to do a process of elimination on this. Washed the bike yesterday and now it wont start. HD tested my battery and it checked out ok. What next?
generally if a bike started fine,, you washed it an now its dead,,, you got something wet,, that wasnt supposed to be wet,, when jt dries it will most likely start..
the circled part is starter relay M923006. youtube "test relay". if that is your problem, the part is not expensive. A few members on another harley forum have said The official HD # is 31504-91a (kfnsme) & The relay from the auto parts store will work fine. Get the relay with the internal diode, usually has a yellow bottom (schmidty)
I just recently was busy about the starter relay, on page 2 if you scroll down was explained how you can bypass
the relay to check if it is the troubleshooter or not : Unplanned `88 FXR !
I assume you're asking what is making that clicking sound?
Is it from the primary or crankcase? Do you hear it better on one side or another? Get an icepick.. er... screwdriver and listen with it touching different areas.
Related Threads
V-Twin Forum
posts
2.8M
members
156K
Since
2001
