Transmission Oil Check 1980 FXEF Shovelhead
17K views 4 replies 2 participants last post by  Machine Vile
#1 ·
How do I check the transmission oil level in a 1980 Fat Bob 1340 Shovelhead?
I've searched all over Google and here but can't seem to find it anywhere.
Thanks in advance for any help.
Machine Vile
#2 ·
Bike needs to be straight up. Pull out over flow plug on side of "kicker" cover. Should get just a little oil wanting to come out.
Tech tip: I use the handle from of a gallon jug of milk to fashion a perfect funel into the tranny. Also, makes life a lot easier if you can make some sort of center stand that fits under the frame rails. I happen to have a cheap lift that a friend welded up for me.
#3 ·
I pulled the allen screw from the side of the transmission kick-starter. There was nothing. I opened the screw cap on top of the tranny and put almost a quart of 40wt oil in there until it started coming out of the inspection hole. I stopped pouring, put the inspection screw back in and the tranny fill cap back on. It's shifting much smoother now.
Thanks again for all the help.
