I have an '82 FLH Electra Glide pretty much all original. If I run the battery down while cranking, the starter will continue to try and turn even after hitting the kill switch - until the battery smokes itself. This is a full dresser with the bolted on battery cover; there is no easy access to disconnect the battery. I really don't want to be close to this thing anyway when the battery starts screaming and smoking. I have read a number of posts similar to this on other sites, and most attribute the problem to alignment issues, spacers, etc.
Everything is great as long as there is a good charge on the battery. I want to wire a ford style starter solenoid in that will disconnect the battery to starter cable with the key off. Has anyone done this? And if so, where did you install it? Anyone have a wiring guide for this? Just hoping not to reinvent the wheel.
Thanks!
Thanks!
