Ride Report: Ricor Intiminators
14K views 11 replies 4 participants last post by  '05Train
#1 ·
Well, between Sunday night and today, I've logged about 200 miles on the Intiminators. These little doodads replace the factory valves in the front forks and supposedly isolate wheel movement from chassis movement.
Let's get this out of the way....No matter what anyone says, there's not a suspension product out there that will completely smooth out your ride, and if there was, you wouldn't want it. You want to feel the road, and you want to know what the front tire is doing at all times. The Intiminator isn't magic, and it doesn't defy the laws of physics. My bike is still a 900 pound behemoth with an antiquated damper rod front suspension.
But it's pretty impressive what the Intiminators can do. Small wheel movements are pretty much erased. There's a sensation of the wheel doing something, but it's muted. Big wheel motions still come up through the bars, but the harshness is gone. Whack a pothole, or a really rough section of road, and it's pretty much what you're used to, though not quite as harsh. I hit an old farm road on my way home today at really ridiculous speeds. This road is downright punishing on the Night Train, and only slightly less so on the Limited. Bumps that would put the bike in the air and my butt off the seat at 40mph were shocking at 70, but the front end stayed on the ground.
One side effect of this is that it highlights what a poor job the factory air shocks do under extreme circumstances. I'm going to try it tomorrow with less pressure in them to see what (if any) difference that makes. That'll have to do 'till the Ricor rear shocks come in.
Overall, the effect of the Intiminators is kind of like Ibuprofen; the bumps, like the pain, are still there, but they're muted enough to make them much more tolerable. I have to believe that between the valving and the lighter fork fluid (Amsoil 5wt), the front tire will stay on the ground better than with a heavier fluid or a stiffer spring.
For the $220 that they cost, they're a must-have for any bike retaining the factory forks as far as I'm concerned. Short of blowing your wad on a set of inverted forks or a Traxxion setup, the Intiminators are probably the best you're going to get out of your front end. The Traxxion is undoubtably a better riding and handling solution. Is it $1,000 better? I can't see that, especially not on a 900 pound touring bike.
#3 ·
thanks for the info. so am i to gather that the gizmos are some type of compression damper, and the rebound damping remains stock? do you have damper rods in both fork legs or just one and the kit includes part to make it two? did that make sense?
thanks
#5 ·
thanks for the link. looks like a copy of the race tech emulator to me. it certainly wont work like a cartridge, but will do what its designed for (compression damping).
question: the only listings i saw for HD said for damper rod forks. but the new baggers (exception being RK) have a cartridge in one side. does ricor have a product for these bikes?
was the damper a reed valve type or drilled holes ? would be cool if it was easy to tune!
#6 ·
The new baggers don't use a cartridge any more. I think they went back to damper rods on both sides in either '06 or '08. I can assure you that there were no cartridges in either of my fork legs.
We're going to put a set on my buddy's '05 Ultra in a few weeks. We're going to pull the cartridge out and replace it with a damper rod and spring. The Intiminator doesn't turn the bike into a canyon carving Ducatti, but it does do a commendable job at settling the front suspension down.
#10 ·
The way I understand it, the Ricors have 2 circuits, and that they have some effect on rebound dampening as well. I suppose you could use a heavier shock oil to control the dampening a bit more, but I think that'd have a negative impact on ride quality. Ricor recommends 5wt Amsoil, so that's what I used.
I was actually surprised by what I found in the forks. There was no spacer, but there was a shim/stack valve sitting on top of the damper rod and under the spring. The '09-'10 bikes also have firmer springs than the older touring bikes.
#12 ·
Yeah, they're still Showa (says so right on the side of the lower). I couldn't believe how much crap was in the fluid after 2,500 miles.
