Twice in the past two months I've pulled my entire primary apart, for different reasons, and put it back together. Both times I fired the bike up, rode it for 45 min or so and parked it. It ran fine. The second time though, I made it about 2 blocks and started hearing a scraping scuffing sound coming from the front of the primary. Some I've heard describe it as rocks bouncing around inside which I can compare my sounds too as well. I oiled up the stator and cover and all parts before assembling and assembled it correctly. I don't understand this and need help. What do you guys think? The compensator sprocket was fine as well as everything else for that matter inside the primary case, these sounds started after I took it apart. Typical... Any advice or thoughts? Thanks, Glenn
