Clutch cable leak
18K views 23 replies 18 participants last post by  joshlong_si
#1 ·
I have a 1999 FXSTC
My clutch cable leaks a drop or two, I hear it is common for the braided type of cables, something to do with the fitting on the end.
Anyhow just wondering if others have seen this and if there is any fix.
Just as soon not have to get a new cable, so I was wondering if there where
any mechanical fix etc. or even if there were some type of gizzmo or goo that could be used ??
#4 ·
Gus said:
I have a 1999 FXSTC
I had the same problem with the braided line and the dealer replaced the cable. The new cable has a black mesh cover that goes from the fitting to just past the engine.
#8 ·
2009 FLHX Braided Leaking Clutch Cable
I too have replaced my clutch cable with new braided cables (brake and clutch). Did this in 10 or 11 and it is now leaking a few drops here and a few drops there. I had my shop pick it up and test/repair/replace?? Hopefully when I get it back it does not leak and hopefully they will cover the repair as I bought it new from them and they did the work. They always take good care of me though, we shall see...:coffee:
#9 ·
Hate to tell you guys this :
Cables can't/don't leak. Cable are made of twisted metal strands.
Hydraulic Lines (clutch/brake)leak. (Hollow flexible tube under pressure when activated)
#11 ·
the "o" ring on the end of the cable at the tranny can leak and an over filled tranny can cause oil to work its way up the cable. I use Barnett cables and they are fine.
But you can get oil seeping at the tranny end
#14 ·
Don't think lubing the cable will cause leaks. Either the O-ring is bad or someone over-tightened the cable into the transmission housing and the cable has a slight crack right there. (used to be a common problem)
You can also check and make sure the fluid is not running down the cable from the mid-way adjustment point. If the tranny is overfilled, sometimes pressure forces fluid up that far and it leaks slightly.
#18 ·
Glad to hear you're all fixed up. Also glad to hear that HD felt obligated to replace it for free.
For anyone else experiencing the same problem - it's usually the o-ring or a cracked tranny side cover but it could also be a cross threaded cable end which may require a new side cover all together. Albeit late, just my two cents worth...
#20 ·
Ed Y just had your answer. If the cable is over tightened in the housing it will crack and leak from around the rubber groumet. If you try to move the cable once it's installed in the housing it will snap the screw in insert on the cable and cause the problem you are describing....been there done that. Dont ever try to move the cable once it's installed. It takes very little pressure to break it inside the tranny housing and cause it to leak.
Just my 2 cents...from No Cents.
@gree:
#21 ·
Hey Chopper Dude, My clutch cable goes into the arm on top of my 4 spd.
So before you start busting my chops, maybe you should get a clue about the difference between old & new. It sounds like the new way is worse than the old way on some things.
