'08 Throttle By Wire Handlebar Swap
39K views 17 replies 14 participants last post by  baggersport
#1 ·
A customer bought an '08 Road King and wanted the same bars he had on his Softail. The bars were not designed for the new '08 with Throttle By Wire.
This first picture shows the new Throttle By Wire in the handlebar end.
The first step in removing the throttle is removing the pins from the connector and pulling the wire out of the handlebar. This picture shows the wires entering the bars at the clamp.
With a small screw driver or pick, carefully pry the assembly out of the bar.
Slide the assembly out.
#2 ·
This picture shows the throttle assembly. Note the green plug. Because we are using an earlier style bar, the green plug presents a problem. In this case we chose to replace the Throttle By Wire system with one from a CVO model that doesn't use the plug.
Here is a picture of the inside of the early style bars. Because of the indent for the wires, the green plug doesn't fit. The CVO throttle assembly resolves this issue.
Another problem is the length of the handlebar from the indent for the wires to the end of the bar. This picture is the new style bar.
This picture shows the old style bar and you can see the throttle assembly won't fit. The bar is not long enough to accommodate the new throttle assembly.
#3 ·
To correct the problem with the handlebar length we choose to lengthen the bar. To do this, we took the stock bar and cut the end off. In the previous picture we marked the throttle assembly with a sharpie and used it for measuring.
Here is the stock bar end with the notches for the throttle assembly.
After measuring we cut the bar end off.
This picture shows how much we are extending it.
After lining up the bar end and tacking it in place, we test fitted the throttle assembly before final welding.
Here is the bar end welded on.
After welding we used a burr to smooth out the weld inside the bar.
The out side was carefully ground smooth and sanded to remove sharp edges that could possible catch the grip.
The new CVO throttle assembly was then reinstalled into the bar.
#7 ·
About 8 hours...including installing the switch housing wires inside the bars (and extending the wiring) and doing the brake lines, clutch cable. The bars were actually 1.5" diameter which required special risers. The risers alone took almost two hours as they created thier own headaches related to fitment of the nacelle.
As a side note, the throttle control wires are 43" long, for both the standard or CVO controls. There was no need to extend them to fit these bars. It is not recommended that they be extended on the throttle control unless you record and duplicate the readings of the throttle control so you don't end up with a drivability issue.
#8 ·
Thank you for an excellent thread with detailed pics....
#11 ·
Nice work, thanks for the pics. HOw does the 'throttle by wire' actually work? Does it use a resistance pot to change voltage and increase or decrease fuel & air based on throttle position?
#14 ·
That's pretty much what the dealer did to mine, except he didn't have to lengthen bars, as the pull back was really long. The Flanders handlebar site has instructions on how to make the modification to 1" bars.. Here you go...
http://www.sideroadcycles.com/AmericanMotorcycles/Handlebars/Stock_Bars.html
You'll need to go to the bottom of the page to see the electronic throttle installation.
#18 ·
No need to do all that anymore for the most part. Lots of bars out now that have that notch built in now. I got the Heritage style put on my '08 Road King Classic. 1.25 hrs of labour, no need for new cables. HD bars have the notch built in.
jober's right. Original h-bar swap in post was done before anyone was making the new bars. Many handlebars are available for the throttle by wire now.
