Woods 8-6 or 9b-6
26K views 47 replies 22 participants last post by  FXDRYDR
I like the TR590 way better than the TW8.........way quieter and pulls hard through mid range.
Question for the pros..............how long could you run a .650 lift cam with stock rockers?
Ozroder
So how much quieter is the TR590 then than the woods? Running a woods 8g on a bagger and it ain't too bad.. Slight rattle it idle which I suspect might be from the travel limiters. I understand the 6h can be noisy.. The 8 running down the valve train sounds like stock.. I did the the gear lash set up correctly..
Ran a Crane 314 chain cam for a while in a 116.. Now that was noisy..
hey bruce i just picked up a set of wild things forged heads..
Hope you got em for a good price, price.. I slowly removing WT parts from the bagger.. Want a set of WT26G cams (no gears)? :)
Bruce
I am an Aussie as you know and I am not trying to promote anyones cams, just giving you my experiences with the TW8.
Well, I don't have Bobby's name tatooed on my chest.. Only cam I've struggled with was the WT26.. Not sure I could tell much difference between 2 identical builds with only a TR590/W8 change.. One cam may favor one build more then another.
So the 8 was in the 103 before? Same heads, CR, pipes etc.
Bassani Pro street turn out pipes and final ccp of 220, the bike has a super strong mid range and it rips!
With a CR of 10.6 to 1, I only get a 200 psi CCP, maybe you missed a little here or there.. What was the CCP on the W8?
In many cases that positive torque slope you get feels like more tq when in reality the peak TQ may be the same.. Prostreets have have a bit of a tq slope to them. Specially on a smaller motor Did you ever dyno both builds?
Bruce
<<I like the TR590 way better than the TW8.........way quieter and pulls hard through mid range.>.
Have you worked with both cams? I have set up quite a few tw8g and they were not too bad on the noise.
<<Hope you got em for a good price, price.. I slowly removing WT parts from the bagger.. Want a set of WT26G cams (no gears)?
Bruce>>
I think you are pulling off the wrong parts trying to figure why performance is down...:whistle:
So what should I be pulling off? Tried 3 different pipes.
Bruce
Wait til he gets about 3000 miles on it. Bet it get a little bit of a personality.. I run 11.3 on my 116 with the grooves and it was nice and smooth for the first 3k. Nice Idle.. Now it idles like a race motor.. Not that I don't like it .. Bike runs great.. No ping on 91 cali gas, but it has a SnS 625 cam in it,, can be break parts if the battery ain't in good shape.. It's sitting right now cuz the battery. Needs a new one.. They only last about 2 years.. Bruce
