· TANGOKING
Hi everyone...
I recently bought a cam that was used for an evo engine. The cam box says it is Wood 6H.. But the cam has only W6 as a stamp..
I know there are two versions of W6.. Could it be that this cam is a W6H cam having a W6 stamp ?
Any help would be much appreciated.
Tangoking
· TANGOKING
Thank you for the info... Much appreciated.
On a 1998 Electra which would be better..
Leinewebber 5s or a Wood W6..
with 10.5 compression.
Screaming Eagle heads.
Crane Roller rocker arms
Barnett clutch
And 6 speed tranny
Thank you
· Banned
The 6H really needs roller rockers.
The 6 does not. Set it at 10:1 or close to it(no more), and it'll deliver great power without the expense of the rollers.
Common to see close to 80 hp and 90 ft/lbs.
