Hi guys,
need help, my 86 softail custom seems to have a wiring problem
i wll be riding along when all of a sudden the bike will cut out and run like it is running on half a cylinder. As if someone has disconnected the battery. Then anything up to 20 seconds the power comes on again then it will happen again within 5 minutes. If any one had the wiring schematics that they could email me would be greatly appreciated.
thanks in advance
Had some corrosion on the damn "short breakers" or what ever they are called. was the one in front of the back wheel. cleaned it changed a couple of lugs on it, seems ok will find out tomorrow when i go for a ride.
i couldnt see the corrosion and i have only had my hog for about 14 months (first one)so i am still learning...but it all comes together on a day out with the boys.............
IF that did not fix the problem, check the easy stuff first;
loose battery terminal connection, loose coil wire, worn out key switch (switch connections). Does the bike run good when not doing this?
Thanks for the reply Larry, I have since put about 250 miles(400kms)
and it has been runnig fine.
