1 - 8 of 8 Posts
OK the tires haven't been kicked to death here about these cams. I was looking at the TC26 (07 chain drive version) to replace the HQ600 on my 107 with R&R stage 4 heads. Mine runs fine but was looking for a little less tendency to ping and perhaps pick up a few HP on top. I may loose a little bottom which I can afford, mine is a torque monster.
Other relevants:
FatCat quiet
HPInc 55 TB
DTT Wego II
With the cam you ahve you could still retain the low end and back the timing off a bit. You will stay have the push over tdc to drive the tq up. You may find that it will even increase some.
I have seen this cam in there entire package and it was not very impressive in a 103 kit. The peak numbers where there but it was rather lazy . Again that is there package though.
Why not run the 615 cam in a gear drive??
Mike Roland is a very generous guy. I've picked his brain a couple times through e-mail. He even built me an ignition map and wouldn't let me pay!!! He's been really busy lately with a Bonneville effort, but I bet he'd shoot you straight if you asked him about his cams vs. HQ.
Steve
From your experience what would you predict would be the results comparing the HQ600, TC26, and the 615?
A lot of cams are specially designed for specific heads and in the case of the RR615 this is no exception. I like that R&R stage 4 head with that cam and have taken several of these to 10.5 to 1 and have no pinging. The way some of these other cams are designed to bloat the cylinder because of inferior port scavenging causes them to ping.
Discussion Starter #6
Randy
I hear ya. I picked the HQ 600 just for the reasons you mention plus it allowed me to use the 07 hydrachain which is a beta test for me before I can recomend the system in a high performance application. The higher lift intake and shorter duration and shorter lift longer duration exhaust mirrors the 615 but has a 47° intake close. The lobes are also assymetrical to enhance cylinder fill. It works exceptionally well but I do get pinging on the hotest days even with a very modest timing curve and a not overly lean off idle to mid range roll-on (ping spot). 107" .035 quench, flatops, 82cc stage 4 heads.
The WT cam actually reverses the duration bias so I am a little nervous about trying it.
Other relevants:
FatCat quiet
HPInc 55 TB
DTT Wego II
I installed wild things T1-G cams on my R.K. and I love em.
1 - 8 of 8 Posts
