I have Wild Pigs Mufflers (2 1/4) with V&H True Duals on my 2005 RK Classic. I see on the V&H website they now have settings for aftermarket exhaust such as Porker,Rinehart and other makes for the Fuel Pak settings. They do not have a setting for my setup with Wild Pigs. I don't know what setting to use, I might try the porker setting with true dual, not sure. I wish V&H would have setting for my "PIGS". If anyone out there has any ideas which setting is the closet to mine, i appreciate your help.
Also, the rear Spark Plug is "white" which means it is running lean, the front one is perfect. The rear tip is fine, just the cone on the plug is white, is this normal??
