davefitch said:
Thinking of changing out my stock Heritage bars to Wild 1 12.5" Apes (WO502). Anybody who's made this change care to comment on resulting bar vibration? Is it more, less, or unchanged? I'm not changing risers or moving from stock bushings- only changing the bars (not mirrors, controls, grips, etc.). I appreciate the feedback.
I've had the 12.5" and currently have the 16" apes on my Road King Classic. At 6'2", I find the apes are most comfortable for me. Having ridden my bike on long distance rides between VA and FL, NC, NY, WI, and completed 1K-mile Iron Butt ride in 18 hours (continuous), I can honestly say experienced no issues with the bike or personal comfort.
Just a thought to consider. I too started out not changing the stock riser bushings. I found that the stock bushings worked great with the low handlebars (up to 8.5" tall), but noticed some "un-nerving" swaying after I went to the apes, especially on turns and stopping. In my opinion, the stock bushings are not firm enough to handle the weight/lenght of the taller apes, so I eventually installed the HD poly riser bushings (simple install, but requires you to remove the handlebars to gain access to riser and bushings). This modification made a world of difference...no more swaying! Either way you decide to go, stock or poly bushing, you should not experience any noticable difference with vibration in the handlebars.
Last piece of advice, if you currently have a two-piece handlebar clamp (like on the touring models), replace the stock clamps with a one-piece clamp. The Chubby bars (1.25" diameter), like numerous others, are designed for install on stock risers (1" diameter). The center area, where the handlebar is clamped to the bike, is stepped down from 1.25" to 1", making this area the weakest point of the handlebar (stomp, stomp!!!). The one-piece clamp will re-enforce this area (recommended by Chubby).
