1 - 17 of 17 Posts
I have a 03 fxst with the dunlap 150 rear tire. I'm told that the metzler 150 would look a little wider. Is that right or is there a 150 tire that looks wider and will fit my frame. I know I cant get any wider than a 150.
Premium octane member
Bean is right...The Avons are running wider than the Metzelers since Metz make the tires in Brazil now. They were the fattest 150 but now resemble a 140 if you are lucky.
avon does make 2 150 sizes though so be careful on which one you chose.
Avon makes a 150mm and a 157mm, and they are both marked 150
Thorns
Thorns
how would you tell the difference? and will the 157 squeeze into a flh rear?
I asked the same thing if the 157mm would fit, but didn't find the answer. Found a lot of people used the 150mm with no problem, and that is true on my 07 FLHR, which I use. Speed rating looks to be different.
150/80B16 ^ 77V is 157mm (Speed rating of 149 mph)
150/80B16 ^ 77H is 150mm (Speed rating of 130 mph)
Thorns
Like txchop says since Metz is making tires in Brazil, you may actually end up with a tire marked 150 that is the same size as a 130.
semi-retired
these
the avon 150/80V-16 and the dunlop 150/80 k591 are the fattest 150's.i had both on my '01 superglide.i now have the avon 150/80h ,little narrower ,better wear,better handling .
Here are some rear tire dimensions to consider.
Dunlop E-3 160/80B16: diameter: 26.10, width: 6.10
Dunlop D401 150/80B16 71H: diameter: 25.45, width: 6.15
Avon Venom-X 150/80-16 71H: diameter: 25.20, width: 5.90
~jerry
The only Dunlop 150 E3 that I've seen was a front.
Front Dunlop E3 150/80-16: Diameter: 25.54", Wide: 5.97"
~jerry
~jerry
Adding to this list, from the Metzeler catalog:
Metzeler ME880 150/80B16 71H: diameter: 25.43, width: 6.02
Metzeler ME880 160/80B16 75H: diameter: 26.06, width: 6.38
However, as TXCHOP said, much of their production is now in Brazil, and they seem to be having problems producing tires which conform to their listed specs. I was lucky and got a 160 size made in Germany earlier this year, and it's dimensions are as listed.
Went with a 150 K591 over the Avon on my 03 Super Glide. The K591 looks fine to me. Dunno if it actually is any wider than the Avon, or if it LOOKS wider, but I went with the reccomendation of an inde for a good, sticky tire - and I am quite pleased with the K591. It actually felt stickier to the touch than the Avon Venom. On the track, my problem used to be wheelspin, now it's wheelies.
If you're just going for the look - the 180s got it!
I had a brazil metzler 150 that measured 140....switched to the v rated 157mm Avon, looks good, fits my 05 FXDL fine.
Hi,
I have been running the metzler 160 from germany measures 158mm on my 03 fxst for 2 years now I would measure the 170 metzler I think it will measure under 160 and will fit under your fender(fender should measure 170mm inside brackets)Am now fitting a 180 under by widenig rear fender 30mm cut frame horns off and moved out 15mm each side and re welded.just down loading some photos will post soon.
sorry cant seem to upload photos
Isn't picking a tire because of how wide it looks a bit silly? I mean, unless you're going to push the bike off a trailer and over to the bike show.
How about traction, profile, construction, handling, durability? Hell, pick it because it's got less road noise at least!
1 - 17 of 17 Posts
