can anyone tell me the widest tire that will fit on a 2000 fxd. I am installing a 16 x 3 softail spoke in place of factory mags. the tire is now 140/90/16 can i go wider without any mods?
semi-retired
150/80-16
I'm runnin' a 150 k591 on my(stock mag) '01 fxd.thin headed bolt on the insie of the fender,an acorn nut onthe strut.very tight fit.you can't fit a metzeler,but an avon may fit.
150 metzeler
I'm running a 150 Metzeler ME880 on the rear of my 97 Low Rider. I use jam nuts on inside with some loctite. I cut the bolts so they do not stick out much past the nut. I get a tiny bit of rubbing on the very edge of the left side on hard bumps. I used a spacer between the wheel and pulley to move the belt over just enough.
Jon
