What's the widest tire you've been able to put onto a stock 2003 wideglide? and what tire did you used?
Come-on cough it up!
:unsure: You telling me, no one out there has put a wider tire using the stock wheel on their wideglide!
There has been plenty of discussion and several very colorful discussions in the past on this topic. You can find that info in the Archive area. The archive link is at the very bottom right of the web page.
Here are some google links to search through archive area. These were set up using dyna wide tire.
Here's a hit list from the Archive DYNA Forum only: http://www.google.com/search?as_q=dyna+wide+tire&num=50&hl=en&as_sitesearch=http%3A%2F%2Fwww.v-twinforum.com%2Fforums%2Farchive%2Findex.php%2Ff-93 If you click on advance you can play around with the search terms.
Here is one scanning all groups in the archive area: http://www.google.com/search?as_q=dyna+wide+tire&num=50&hl=en&as_sitesearch=http%3A%2F%2Fwww.v-twinforum.com%2Fforums%2Farchive%2Findex.php
You can alter the links once in google to zero in better on your particular topic.
