My 03 Wide Glide is leaking fuel from what appears to be the weld that holds the rear bracket to the tank. Has anyone else seen this?
Welcome to the Forum.
Presume you have removed the tank from the bike and drained the fuel. Was the rear bracket to frame connection under much stress? Do you see any hairline cracks in the paint? Any unusual wear to the under tank wiring?
Fortunately, I have not had this problem.
You might look at this not as a problem, but as a reason to get a custom paint job.
