1 - 10 of 10 Posts
I believe I have found a leaking exhaust gasket and before I replace with another of the SE variety, I thought I'd see if anyone here knows about a better alternative?
XLIII
Stock or, since you DON'T have Rineharts, the gaskets that come w/ them work well on V&H pipes. If the tech at your dealer is worth a crap, he probably has a pile he didn't use.
The flat SE exhaust gaskets are known to be difficult to get a good seal with. I have read about people using two together to male a good fit. I just said the hell with it when I put on my exhaust, and used the stock crushable kind. I have read that when using the stock gaskets, since they crush, you can end up with a small amount of gasket material protruding into the exhaust port area. I never thought that it could be enough for me to care about (although that may just be my ignorance). It was more important for me not to have a leaky exhaust.
Thats the reason the guy at the parts counter told me to get the SE kind. I think I have a set of the stock cone shaped ones laying around...but I thought I'd check to see what was the latest and greatest before making a decision.
Which ones should you use if you have rhineharts?
Agree 100% with above statement. I used the se gasket because someone said crushables could get into the exhaust stream. However, after having just removed my exhausts and looking at the se's I am sure they were no providing a good seal. Crushables from here on...
I've been told SE by knowledgable people here and put them in when I had an occasion to remove my headers. No problem... just put them on according to the manual and sealed up fine.
I just received my new revised bracket from Rinehart and it came with new gaskets... can't tell the difference from the SE. I read somewhere in their literature that they use something called a James Copper Gasket... like I said... looks the same.
killer sperm
I had Cometic "race style" exhaust gaskets that were too big to fit smoothly into the resess. They ended up smashing into the port. SE gaskets fixed that problem.
Discussion Starter · #10 ·
yeah....I saw your posts on HTT...thanks for contributing MH.:beer4u:
1 - 10 of 10 Posts
