What I bought was the stretch tank with dash. Let me tell you up front this is not a simple bolt on application. There is lots of work involved.
1. Tanks are pretty raw, lots of body work to be done.
2. sh1t dont line up like its supposed to, for example the deppression in the tank that the dash actually fits in was off center a quarter of a inch, so I had to fill part of in with bondo.
3. The electrical plug that goes into the back of the speedo will not fit through the hole in the back of the oem speedo when you take it apart, so you have to take the 8 pin connector apart.
4. I dont give a fu(k what they say the coil will no longer fit under the tank, maybe it will with a flat bottom sport bob but it wont with a strech. A pic of my solution is posted below.
5. Many little things to overcome, lots of $$$$ about $350 for the tank, $$ for paint job, about $200 for my answer to number 4 above.
6. There are other problems I have encountered but I cant think this early.
I should get the tank and fenders back today
Bottom line is this is a lot of work, and alot of money. It will dramatically change my bike and worth it to me
