Which kit is the best for doing a chain cam swap?
I have looked at the HD SE kit and the S+S kit is one better than another.
Thanks for the help.
Jim
I would go for the S&S kit as it has a better inner cam bearing Thorrington i think which has more needles in the bearing making for better weight spread,
the harley fits have less needles in the bearing.
Thanks guys.
That is what i thought but needed reassurement.
jim
The aftermarket kit use torrington and the SE (stock) use a INA style, I will have to say that I have not seen a inner fail in a T/C though, evo yes. Ihave seen outer bearings that are blown apart the inner cam surface badly damaged and the bearing when removed looked good rolled smoothly and had no damage to be found. I do replace them but then seem to hold up well in the t/c
Discussion Starter · #6 ·
Tools
Wrench, I have been told that you rent the tools to do the cam swaps. Is this true? Let me know if you do and what i need to get them.
Jim:thanks:
