2001 Softail Heritage
I am out in the garage now trying to figure out how many plugs to remove to drain the engine oil. The owner’s manual clearly shows the transmission drain and the primary drain, but skips the part about engine oil drain. And the service manual that I ordered five weeks ago still has not arrived.
Looks like two or maybe even three plugs to remove – one for the tank which is clear to see. But is that the only engine oil drain location? There are two hex-key drain plugs on the bottom of the case. They are on the starboard side about two inches from each other; one a little higher than the other. Are these drains, too?
