1 - 11 of 11 Posts
I'm getting a new rear tire. Goin to tear the wheel down on sunday and leave it to the shop on monday morning.
I did also order a (dynamic) wheel balancing.
Shop is closed now, and I'm not sure if I need to take off the drive belt pulley and/or the the brak disc from the wheel for the wheel balancing.
Someone who knows how this should be done?
Thanks!
/Dan
Should be done with pulley and rotor, they're all of a piece and will affect the balance of your wheel...
I hand carry my wheels to dealers all the time for them to mount new tires and never remove pulleys and/or rotors.
Depends on what wheel. Sometimes its a real Wh**e to get the tire off without scarring the pulley. I'd pull that off, and leave the disc. Of course, you'd wanna get some torque specs and a little loctite of the correct flavor(whatever the manual specifies). Definitley don't want that comin loose down the road. I think they might even specify that you change out the bolts, but uh, ya know... your choice there.
Thanks guys,
Thats just my thoughts.
I'll leave the disc and the pulley on. When I get the wheel back I'll check the bolts with given torque per manual for the disc and pulley.
Thanks,
/Dan
When I had my dealer doing my tires I assumed they balanced them, I never had a vibration with either my sportster or my Electra Glide Ultra. Now I took my bike to an independent and when he was explaining that he had to drill out a snapped off pull bolt, I assumed it was already broken from the dealer. But he said no, it snapped when he was removing the bolt. I asked why was he removing the pulley and he said it was that he didn't want to take a chance of scuffing the pulley. So now my question is, what does the dealer do? Do they have the right machine and the pulley stays on? I mean, if this guy has to remove the pulley each time, that wheel is going to be toast after awhile. Maybe I'm taking to to a guy with the wrong machine?
My indie leaves everything on.
I just learned something here. The tires that I have balanced in my own garage have all been balanced with the rim only. I hope to never mount another tire in my garage, but you never know. The dealer could piss me off again and I could lose my mind like last time.
i left it all on,,, it is easier,,, antone who removes the rotor and pully,,, is somewhat brain dead in my book...
I pulled my pulley on my spare set of wheels, think I had to to get the bearing out. Had to convert from the metric axle to the 1 inch axle. The front rotors stayed. And yes I bought new bolts for everything, technically they are supposed to be replaced, not taking chances for about $15 worth of bolts.
Been there,,, I did one that took me 4 hours to finally get the bead to seal. I was totally used up after that ordeal. Never want to do it again.
1 - 11 of 11 Posts
