1 - 8 of 8 Posts
I've got a 2004 Wide Glide which I've been riding for about a year and a half. At 1000 miles, the dealer installed the Stage I mod, and also (at my request) removed the inner baffles from the stock mufflers. At the same time I had them install a mini-tach on the bars. The bike runs great, and I'm pleased with everything, except I've had a buzzing noise ever since. It's not terribly loud, and I only hear it while running even or accelerating. I don't hear it at idle, and can just barely hear it when decelerating. Frankly, I don't know if it was there before the mods (I didn't notice it, and the exhaust was much quieter then), or if since. I can't even seem to localize the noise...each way I turn my head while riding, it seems to follow. Each time I'm at the dealer's for service, I ask them to look into it. No one there, including the service manager says they can hear it. It's kind of surprising since I'm half deaf myself ^rolleyez^ This bike is the only Harley I've ever ridden, so I don't even have a point of reference as to what sounds are "normal".
And yes, the dealer and I have been all over the bike looking for something loose and buzzing. No joy :(
Anyone have any idea what this might be, or am I just hearing a "ghost" sound?
Jack
check your exhaust clamps where your slips are clamped and also where they mount to the frame. I had the same noise on one of my fxd's and it was the exhaust vibrating. I can't even remember what I did to solve it......if I just snugged up the bolts or maybe used a washer if they're vibrating against something. It's a starting to point anyway...good luck on your hunt.
I experienced the same "buzzing" noise and finally discovered the heat shield on my V&H needed adjustment. Thirty seconds with my screwdriver and the buzzing was gone! Considerably less time than it took to figure it out!
I had a buzzing noise one day on my bike, it was driving me nuts thinking something was wrong with my bike. I looked all over and found that the visor that came with my half helmet had came loose. it was the snap that was loose causing the buzzing noise. I don't use the visor anymore, didn't like the thing anyway.
good luck and ride safe.
Thanks for the suggestions. I'll spend some more time this weekend with wrenches in hand, and I'll focus on the exhaust. I'll report on anything I (hopefully) find.
Jack
Just a thought, Had the starter drive go on my Deuce . Couldn't hear it buzzing over the pipes . Started fine but occaisionally wouldn't fully disengage. Finally heard it at idle , I hit the start button and it retracted with a clunk . Had to rebuild starter drive .
good luck
sno
Hi,
stupid sounds on my 94 LowRider caused by this:
1. Rubbermount engine block under the gas tank ( put some
silicone spray on it )
2. Side stand vibrating on the frame during riding
3. Heat shields of the exhaust
Good luck,
271ABN
1 - 8 of 8 Posts
