Here's the story, I have friends 2003 Fatboy on the lift. It had front cam bearing failure. He was running down the highway when it went out, so it ran for a while after it fell apart. The motor was built by a HD shop here in 2007, they used se 95" 10.5 pistons, se 251 cams, and se springs, and HD cam install kit with sh!tty bearings. The heads were also ported. It has the MM fuel injection with a se tuner. The bike has about 70,000 miles on it now. The cam ate into the case pretty deep, ruined the right side crank pinion, and the cylinders and pistons are done too. So what would you guys do? Rebuild everything or find a new motor? Has anyone ever machined out a cam journal and installed a sleeve or welded and machine it? Thinking about boring it to a 98 and running S&S 551 cams and changing the fuel injection to something bigger and better. The stock crank can be rebuilt and welded, I think, I haven’t split the cases yet. The bike has a bagger kit and the owner is a really big guy. He also would like to have more torque instead of wide open hp. Any ideas??????
