Game plan is for a HiPo street, 95ci, Weissco 9.5-1cr pistons with ported stock TC88 heads with bigger high flow valves, with springs & retainers to match, SE roller rockers and rocker support. not going for max port size in the heads just a cleanup on the intake and polishing the ext. with some valve pocket blending work, what size/which brand of valve do you recomend?
for a cam i'd like all the midrange TQ under the curve i can get without killing bottom and still have reasonable HP on top. been looking at SE 251 & SE 257, can you recomend a brand/grind?
i'll also be running SERT, 2nto1 header, SE/K&N aircleaner filter.
thanks
:choppers:
thanks
:choppers:
