Had a problem with sumping , was going to replace oilpump. Checked the crank run out and it was 20,000 . What should i do? also camplate looks like it should be replaced.
I assume i need a new crank now, don't want to spend a fortune . so What do you guys recommend?
Check around for a take-out set of flywheels....local dealers and there techs are the best source as they will have done a few 103" builds with the 88s. You should be able to find a set with little or no miles on them for a song.
If your singin voice aint good, you should be able to find a set for cheap$ with cash.
Serious Mori....let me know what you find....
Bean
Thinking of sending my crank to King of Cubes or Dark Horse, for trueing, balanceing and welding and getting the Timken bearing put in.
What camplate should i get ? I have gear drive cams.
