That little plastic shim or washer between breather and camcover.Don't recall shimming the Breather...
I think I recall an end play tolerance on the breather, but I'll be damned if I can remember what it is.Don't recall shimming the Breather...
There is a select fit washer on the end of the breather gear.I think I recall an end play tolerance on the breather, but I'll be damned if I can remember what it is.
But maybe I have it confused with the cam.
Yea... never even measured one...That little plastic shim or washer between breather and camcover.
There's your clue so I don't think it's the breather gear.I feel a little extra tightness on every fourth rotation when spinning the crank.
In the spec is all I worry about.Question... How much end-play are you shooting for on that Cam??
In my Experience, Looser side of Spec is better than Tighter... for My Needs... Never ...ever burned a Shim!!!!
OK, except on a 4-speed Sporty Tranny!!!!!
I set it in the middle of the range a loose .008, thats following the harley manual instructions of mounting the cam cover with 4 bolts, but no torquing of the bolts then checking the end play.Question... How much end-play are you shooting for on that Cam??
Personally ... I torque the Cover with Empty cavity... Makes me feel good just in case the gasket squishes a bit..I set it in the middle of the range a loose .008, thats following the harley manual instructions of mounting the cam cover with 4 bolts, but no torquing of the bolts then checking the end play.
You think this ok?
I still havent torqued the cam cover yet. back to work tomorrow for another 3 weeks, hopefully i can get on the road by autumn.
You happy with the new fork springs and emulators?Got rained out of the Gettysburg Bike week show last weekend. But took it on a Vintage Bike Night dinner ride to Mt Joy yesterday.
Love them.You happy with the new fork springs and emulators?
Thanks Racepres, found this on the Forum.Ronnie Trock SR Jugs... He made a Jillion of them..
I still have a Plethora of Ronnie's Parts, may even be a trap door left around here... he was Famous for them... Almost as Famous as his Welders Hat!!!
