Looking for trouble to close to their coulorsI'll bet Outlaws MC won't appreciate those shirts. Just saying...
It just felt like extra slack in the lever.Can you describe what that "extra play" feels like?
Greg
Small plastic screwdriver handle.Any tips on locking the pinion gear when torquing the nut?
will cost me 140 bucks for the georges garage locking tool, which ill use once.
I'm using a set of Race Tech springs. The springs that were in it were just oem long fork variable rate springs that had been cut down three inches to increase the spring rate.Can't wait to do this myself. Are you guys putting in new springs for any reason (progressive).. ?
Why glad? Emulators won't work on these forks unless you drill the tubesI'm glad to see that you drilled out the damper rods.
You can also tune it with the tension on the blue spring.
I had a real noticeable improvement in mine, before & after.
IIRC years ago (when I put mine in) there was a discussion wherein you said, that you were told by someone, that drilling out the damper rods was not necessary and didn't make a noticeable difference.Why glad? Emulators won't work on these forks unless you drill the tubes
I like it too!A long over due rotor change as my old ones were down to 4mm, the minimum is 4.5mm. Splurged a little bit with these EBC floating wave rotors along with their semi-sintered V pads. I had a bit of trouble getting the rotor bolts out, soaked them over night with liquid wrench. Also had to cut a notch in a rotor to accept the speedo drive as I have a sealed bearing, 2000+ wheel. I like the contrast of the modern rotors and the old school wire spokes.
I don't recall saying that about emulators. If you don't open up the rods, then the rod will limit the function of the emulator once it reaches maximum flow. The rod has to flow more than 100% of what the emulator valve will flow.IIRC years ago (when I put mine in) there was a discussion wherein you said, that you were told by someone, that drilling out the damper rods was not necessary and didn't make a noticeable difference.
I like it too!
What weight oil did you use? Im installing them in my forks tomorrow, racetech recommended 20wt, i alreadyhave 2 new bottlesWorking on forks today. Adding emulators and custom springs.
Just as an FYI for them that wonder just what the hell emulators are, it's a little adjustable spring-loaded valve that takes of the function of the fixed holes in the damper rod.
The gold part in the photo
As oem the fork just uses 2 - 3/16 holes in the damper rod to meter oil and control ride quality. It's a very minimalistic (cheap) way of doing it, and you end up with the well known Harley mush front suspension. The emulator turns the fork into a valved shock absorber.
This is a damper rod after modifying it for emulators.
The two holes marked in yellow get drilled from 3/16th to 1/4 inch. Then 4 more 1/4 inch holes get added, marked in blue. Then you chamfer them for good fluid flow and put it all back together. This basically removes the damper rod fulit control function and allows the emulator valve to take over.
What weight Oil you use? Im installing them in my forks tomorrow, ractech recommended 20wt, i already have 2 bottles of 15wt so will give a try with that 1st.Working on forks today. Adding emulators and custom springs.
I mixed some that I had on the shelf. 1/2 and 1/2 with 15w and 20w, so 17.5w would be the result. I still have the 20w that came from RT, but thought I would try using up what was already on the shelf first.What weight oil did you use? Im installing them in my forks tomorrow, racetech recommended 20wt, i alreadyhave 2 new bottles
