2061 - 2080 of 2098 Posts
I'm just hoping I can find the rod hole with the pin on assembly as easy as it came out.
Stick your little finger in from the back side. Just to be clear on this, backside of the piston. Then use your finger to line it up. Do be sure to use a new clip.
I've got 4. Hopefully I'll only need half that.
Rode the Gyna to Harbor Freight this morning and picked up more brass brushes for my Dremel to clean the old gasket off. It's kind of a Teflon. I've never seen one like that before.
Prolly had silicon beaded gaskets on it. Try wiping it off with carb cleaner on a shop rag.
Nope. I've had those on primary gaskets. It was blue Teflon like material.
Carb cleaner and brake cleaner are scared of it.
Edit: took a picture. It's blue and brittle.
Some times you just have to break out the razer blades.
Already did. Now the brass brush on the dremel to finish.
Hopefully I can get started on reassembly tomorrow. Seems like it takes 10x as long since I have to clean threads for loctite.
Meanwhile somewhere in northern Europe ...
Before trip battery voltage was just 10.6 V , so i started engine with booster (extra battery). Today was "very warm" weather, around 11*C (52*F). It is not unusual to have 10 cm snow at this time of october. After trip (just 100 km - 60 miles) it was nice to have sauna to warm my frozen body.
Blew the snot outta my pinion shaft gear when it popped back thru the carb in reverse rotation as I was starting it.
267196
1984 fxrs
Snagged these.... they are 3/4" sealed bearings. They have a 2-1/4" hub though so ill need to figure out brake rotor and sprocket situation to get them on the bike. And some spacers for the front since its a narrow hub and I have the wide glide front end. I assume they were intended for 2000+ applications that had larger rotor center bore and stuff. Ill figure it out. Maybe.
Sent from my SM-N960U1 using Tapatalk
Changed oil & filter, and primary fluid. I've been running a Rivera Pro Clutch for a few years and the amount of ATF they recommend is a bit vague, "fill to the bottom of the ring gear." You can't really see the ring gear, it would be very little oil I would imagine. HD recommended about 1.5 quarts for the stock clutch. I started with about 28 oz. and have been going less with each fluid change, since downshifts can be sticky. This time I added only 20 oz. and downshifts are much better, and it feels smoother at high RPM's. Was wondering what others with the Pro clutch are running for fluid amount?
1992 FXRS-C
Put a new saddlemen seat on and took advantage of the nice weather here. Was rather short lived tho as I believe the shifter pawl spring failed on me. Have to move the shifter back to center after every shift. As much as I hate to admit it, this seems like a little more work than I’m willing to take on at the moment.
