It's not a lubricant.
For what you want to do, buy a can of Tri-Flow. It will work a million times better.
WD-40 is mostly a solvant. Be careful.fxrflh said:It's not a lubricant.
To make your clutch smooth install an easy clutch (cheap after market part) and then squirt some dry ease down the cable working the clutch lever. It will be easier to work than a hydrolic clutch (no kidding) if you do it properly. My clutch is like butter and it is all from doing what I stated.OneBlackFly said:Just wonder if there are any problems with use of WD-40 as an all-purpose lube, such as for brake pedal bushings, clutch lever pivot, etc? When I say 'use,' I mean small amounts, not soaked! Thanks.
Do you have a link for dry ease? Thanks.Fatb0y said:To make your clutch smooth install an easy clutch (cheap after market part) and then squirt some dry ease down the cable working the clutch lever. It will be easier to work than a hydrolic clutch (no kidding) if you do it properly. My clutch is like butter and it is all from doing what I stated.
@gree: that's itSprung said:I think the name WD-40 is from its creation process. It was the 40th attempt at a formulation for an agent of "water dispersion (or displacement)".
Take your favorite tie with the stain in it and soak it in the WD-40. Hang the tie up and then you will have a very clean tie.%[email protected]OneBlackFly said:Just wonder if there are any problems with use of WD-40 as an all-purpose lube, such as for brake pedal bushings, clutch lever pivot, etc? When I say 'use,' I mean small amounts, not soaked! Thanks.
read that in the back of handyman magazine too, huh.Sprung said:I think the name WD-40 is from its creation process. It was the 40th attempt at a formulation for an agent of "water dispersion (or displacement)".
Now that's good advice. Got some frioles on a tie the other day. I'll try it.wkohn said:Take your favorite tie with the stain in it and soak it in the WD-40. Hang the tie up and then you will have a very clean tie.%[email protected]
