1 - 18 of 18 Posts
Someone told me this last evening and I'm just curious. I hope the problems have been taken care of on the 06's
It wasn't a leaking problem per se... It was bad valve guide seals, but not on all '05s... just some early production units. My RK had the bad seals and was using about 1 quart of oil per 1000 miles. No drips, no smoke, just disappearing oil.
I didn't know what to do until I found this forum... the boys here were on it and gave me all the info I needed to wake up my local dealer.
HD is aware of the problem and will replace the valve guides at no cost. A lot of folks, myself included, took this opportunity to upgrade to the 95ci kit while the labor was free.
Infidel
Hi Dave,
Not leaking per se, but excess consumption due to bad valve seals.
There are many threads on this topic.
regards,
wyo
Just Above Idle
Old School:
When does a Harley Stop Leaking Oil ???
When It's Empty!!!!
:roflback:
Mines a "06/2005" scoot. I havent noticed any significant oil loss. I'll pay closer attention now but havent seen anything concerning yet.
Thanx for the tip 8-ball!! :thumbsup: I might just go ahead and tell them mine is consuming oil. :D
Is it?............
Administrator
Here's a thread that explains the problem in detail. http://www.v-twinforums.com/forums/showthread.php?t=63946
Not all '05's have excessive oil consumption but they all have the problem. The "bad" valve seals were used into '06 as well. The fix HD implemented (updated valve seals) treats the symptom but doesn't cure the problem. Even with the new seals, the oil is trapped in the base of the valve seal/spring seat.
Infidel
You can tell them anything you want. Before HD pays for anything they will verify your claim. Specifically, there are protocols to diagnose and document excess oil consumption.
Visit HarleyHog's Lair. About half way down the page you see a link called Diagnosing Oil Consumption.
This will give you some idea about the process.
regards,
wyo
regards,
wyo
Funny.... that is what the manager at my dealer told me... sent me back to talk to the service manager to begin the process... the service manager pulled the plugs, and scheduled a tear down.
Unfortunately, I just found out from Steve at GMR who is rebuilding my motor, they used new bad seals. They didn't use the upgraded orange one. Although, to be fair, I seem to recall the first of the newly redesigned seals were still black which caused a lot of confusion. This led to the change in color... this could also simply be part of my recurring nightmare.
You're asking about oil leaks in late model Road Kings. Yes, there was a problem. Some of the touring bikes developed leaks from bad shifter seals.
2001 FLHR bad shifter seal.
1 - 18 of 18 Posts
