premium member
Hi Guys i need some advice this is my set up at the moment
10.1 wiseco pistons
30 thou cosmetic head gaskets
comp 10.2.1
stock heads port/polish
back cut valves with 3 angle seats
intake and intake manifold floor raised .250
mikuni 42 with yost
python 3 exhaust
crane hi4 ign
cam ev46
hawgbreath filter
nitrous (not used yet)
is it worth me going to a wood w6h would there be a improvment in hp/torque or not worth the expense
I thikn the R&R 56 would work extremely well with your build. The cam you have is not bad hard to say what gains if any you would get with out know to what amount of head works was truly done. It sounds like the ports where welded, and then ported so what size valves are you using.
Cams
The Bob Wood W6H will spank the 46 on the torque.
Torque is what creates the rate of acceleration..........
premium member
Thanks for the reply guys as any one else changed cam and gone to a wood w6h if so was it worth it.
