Ok just purchased new ultra classic, now I am new to HD so when I started to unload my new bike from trailer the dang battery was to low to turn it over. So I put a trickle charge on it overnight. (trickle charger said charged OK next day) Ok next day on my maiden ride I noticed the volt meter stays at 15 VOLTS isn’t that excessive, it ran good for 60 miles till I got home, still staying exactly on 15 volts, (fired right up later)would someone tell me to take this thing back to the dealership or what to do with it???
03 FLHTCUI
I've got an "03 Ultra, with a Trike conversion, and don't think I have seen the volt meter off of 15 volts for the 26,000 miles I've put on it. Oh, yes I did. Last winter I had the electric gloves, liner and socks on, all the lights running, the radio on and I was sitting in the drive way warming up the bike, and at idle it dropped down to 13 volts. Must be the guage, but I never have had a problem.
Ride Safe.
Walt
inconsistent voltmeters
I'd say that every bike with a voltmeter seems to have its own reading. It is as if the voltmeters are just there and generally it is inaccurate. I have two bikes, both twin cam glide's: one reads closer to 15.5 volts and the other 13.5 volts. A fly-and-ride I rode for two weeks read 14 volts. Why are the different? Who knows!
To me the voltmeter has only two values: one if it reads lower than 12 volts you got a problem; if it is not constant at its reading you got a problem. But what voltage it reads when everything is normal is bike dependent.
03 Heritage
I don't have a voltmeter on my softail, but I have measured the voltage on my bike with a digital mult-meter and a twin-scan 88 tool. Around 14.2 volts is common/normal when riding. I'll bet that 14.2 could look like 15 on a dash gauge that probably isn't too accurate. I'll bet your fine. If you can measure your voltage with a known accurate meter like a voltmeter it may help put you mind at ease.
Premium octane member
Just check it to make sure is good, then take a mental picture of 15v and if it moves then look for a problem. Mine has been same for the little over the year i had my bike.
Discussion Starter · #7 ·
15 volts to high
Thank everyone for your comments; i can now sleep at night
Knowing it is in range with most of the other bikes. Down deep
Inside i figured a new bike should have been checked out and the Big
OK put on it. But the situation was just a surprise in thinking it should be exactly on 12.8 volts. Hey thanks again.
