Yea i kinda agree, but just adding that extra layer of protection. The whole cam blow up issue the twins have scares me.
Eh! Wayne,
I can sympathize with what you & Tutt are saying about the cost of gear drives. The gears alone are as much as the HD hydraulic upgraded tensioners, plate & high volume pump.
The real plus with gear driven cams is you can put the tensioner issues & doubts of when is it going to give me troubles again to bed. There is also a 3hp gain but the best part is your valve train timing will be running exactly where it should be all day long.
The gears have tolerances. The max run-out is 0.003 for them which is well under HD'S tolerances of crank run-out of 0.010. The first requirement would be to check the crank run-out.
If I didnt fall into such a good deal on a new set of S&S gears for 125.00 & the Andrews 37G's for 100.00 I doubt I would be going to them even though my run-out is 0.0015 pump side. I would be going to the new SE plate & pump.
