New member asking for advice from you experienced riders/mechanics:
Will doing a straight SlipOn job, without adjusting fuel/air ratio & ECM, cause new V&H Turndowns to turn blue or yellow? I installed these last night, and man they sound sweet! The reason I ask this question is because I came across another touring bike in my area and noticed he had the same set-up, only he had the cone tips on his slipons instead of the turndowns. He was running stock A/C and stock headers. On the right side muffler, where it slips into the header pipe, was a hazy streak of yellow about 4" long. 'Anyone experienced this?
I'm currently waiting for the rest of my parts to arrive being T-Duals, PCIII, and A.N. Big Sucker. However,the A/C is on back order and no telling when it will fill in (1-week minimum). I gotta work with the cheaper online stuff to fit my budget.
--Any advice welcomed, thanks!
I wonder if the slip-on wasn't push-in quite the whole way and there was an air-leak at the place where the muffler joins the header pipe. Just a thought. I personally would add the A/C and then a power commander just to make sure enough fuel was getting the engine - the engine runs awfully lean in the stock form. Would help with heat too - summer's coming and the engine runs very hot when leaned to the EPA specs.
Thanks for the advice Ted, I'll make sure the mufflers are pushed in and clamped down enough to prevent a leak.
I've read that the bikes are set to run lean out of the factory, but are they set so lean as to cause the mufflers to change color? Remember, all I changed out were the stock mufflers to these slipon V&H Classic Turndowns.
