Hi everyone. My question is, with a stock aircleaner & stock jets can I put my new V & H's on my 03 883c & ride it for a day without hurting anything, or is this a bad idea? 480 miles on bike~ Thanx, Mark
Would not hurt for a wile, run the baffles. You can check the idle mix screw, the plug can be drilled out useing a 90 deg drill and a small 1/8" bit without carb removeal, you can richen up the slow speed circit from the get go & when you rejet the plug is already out.
