I'm Marcello from Italy and I'm running a Underground build with this setup:
95” SE cylinders
SE domed forged pistons
Underground Heads decked at 83cc (CR=10:1), Crane spring 155
Cometic .030" head gaskets
Andrews TW 37b
Crane Adjustable Chromemoly Pushrods
JIMS Big Axle "powerglide"
SE adjustable map ignition system
Mikuni HSR42
SE Big-bore manifold
SE air cleaner
V&H Pro-Pipe
If in the future i would swap to gear drive which are the best cams that works with this kind of heads?
I would stay with CR near 10:1.
What do you think about Woods TW5G cams?
Thanks in advance for your help.
Marcello
95” SE cylinders
Andrews TW 37b
Mikuni HSR42
SE air cleaner
V&H Pro-Pipe
Marcello
