I'm Marcello from Italy and I'm running a Underground build with this setup:
95” SE cylinders
SE domed forged pistons
Underground Heads decked at 83cc (CR=10:1), Crane spring 155
Cometic .030" head gaskets
Andrews TW 37b
Crane Adjustable Chromemoly Pushrods
JIMS Big Axle "powerglide"
SE adjustable map ignition system
Mikuni HSR42
SE Big-bore manifold
SE air cleaner
V&H Pro-Pipe
I contacted Colin of Underground Performance and asked him If in the future i would swap to gear drive which are the best cams that works with this kind of heads.
He reply to me that the TW-5G cams will give me more performance than what i have, and there are no problem with the lift because my heads will accept TW-6HG cams and those are .590 lift so the TW-5G cams will work well.
What do you think about? are TW-5G a good choice.
Any advice will be greatly appreciated.
Thanks in advance for your help.
Marcello
95” SE cylinders
Andrews TW 37b
Mikuni HSR42
SE air cleaner
V&H Pro-Pipe
Marcello
