First off let me pretense this thread with the info that I am NOT very versed in the TwinCam motor or its functional enginering.
That being said,,,, I have read many threads discussing the pros and cons of different cam configs and I was wondering,,, If you cam a bike for high rpm HP and loose your low end torque, or you cam for torque and loose the high end scream, what is the poosibility of using TWO different Cams in a twin cam.
Would it be possible to cam the leading cylander (front) for torque to get that snot off the line and then cam the trailing (rear) cylander for the high rmp scream and therefore bridge the gap and give a little on both ends?????
If Yes,,, why is it not being done?
If NO, again Why?
Please be technical in your responses, I really would like to learn something here.
If NO, again Why?
