Can someone tell me the difference between the SE 44mm Pro big bore carb part #27934-99 which is not cruise control compatible and the
SE 44mm street legal big bore carb part #29635-99 which is cruise control compatible. I'm doing a Zippers 95" Muscle kit and I'm not sure which carb would be better, or what the difference is, if any besides the ability to attach cruise control....Thanks
there is only one 44mm big bore carb and the #27934-99 is the only one. the part number you gave for the second carb ##29635-99 is the Big Bore Intake manifold. Sounds like you and i are looking for the same thing and want to keep the use of our cruise control. I was told that aero Cyle makes a cruise adapter for this carb. Good luck . Booggerbe
0043--Licensed to Doof!
SE ,makes a cruise compatable 44 CV. I had one on my 2003 EGC. Got it from my HD, part #'s in the Screamin' Eagle book.
There are 2 44 cv carbs - one street legal and one not. The bodies are identical - they function identically, only the jetting is different which you can change. The street legal one simply allows cruise cable to be attached.
