Run silent chains are a problem, or rather thanks to the heavy duty springs the tensioners came with they became a problem that didn't have to be. Look at the damage evident on the stock shoes, at least the ones that haven't completely crumbled.
Looking at just the shoe, nothing else, the damage doesn't make sense and has caused many to suggest the random pockets of missing shoe are most likely unseen air pockets caused during the manufacturing process. The pockets are supposedly popped when wear reaches the air pocket.
HOWEVER, when you place the shoe against a run silent chain, what appeared to be random pockets are not random at all. EACH hole lines up PERFECTLY with a plate of the run silent chain. ONLY a run silent chain is capable of producing this damage, it is 100% IMPOSSIBLE for a roller chain to duplicate the same shoe damage.
The spring tension is way too much, forcing the run silent chain to dig into the shoes and the tension is enough to pull the sprockets, placing pressure on the cams, scoring the bearings.
Hydraulic tensioners with run silent chains would not have been a problem nor would the heavy duty spring tensioners with roller chains have been a problem. But the heavy duty spring tensioners combined with run silent chains caused the shoes to crumble and clog the oil pump and oil passages.
What's worse is that no one knows when failure will happen.The following pic is of the cams and bearings from a 2003 FLHR that was converted to S&S 509 gear drive.
Judging by the pic, how many miles would you say were on these bearings and cam? 7,000. Yup, just 7,000 one owner miles with all service records.
Hard to tell by the pic, but that's some serious scoring. The cam is pitted...PITTED. Ironically the shoes weren't that bad, I mean, as far as heavy duty shoes go, but really bad for just 7,000 miles. Some people get 80,000+ miles without a problem, some have destroyed themselves with under 2k
