1 - 9 of 9 Posts
Ok,got bike back last night,first thing I thought,it's noise.Thought the 211s sounded better.But,today is a new day.Fired it up and wow,it's a very DEEP GROWL,very loud,I like it!!! The noise isn't as bad as I though it was last night. The power is where I want it,low to mid rpm.I did install the 4* advanced gear also.So,I am happy with the cam swap and power.(FOR NOW) Thanks to everyone who gave me feed back on this project.
Sounds good did you do the heads? What comp ratio and pistons
etc ?
I've got that cam in the "H" version and a 4 degree advance also. It is my third set of cams in this motor. These are perfect for me. My head guy got the geometry right in the valve train, so they aren't that noisy at all. I'm running 9.8-1 and it runs very strong. I've been tempted to add some comp and run them straight up, but so far I'm leaving well enough alone.
tw6 install
My heads where already ported,9.5:1 compression.I run a thunderheader and like I said the sound is hard to beat
Sounds good Secondchance, glad your happy! Let us know if you get a dyno curve, I would love to see that. -Tutt
I'm glad you got it installed. It's a good cam.
Mike
Discussion Starter #9
Thanks Mike,again for that cam and gear set.They come on,just where I want them to.Could use more compression.That may be next.
1 - 9 of 9 Posts
