1 - 2 of 2 Posts
I just bought a 2007 bbc with an S&S 100 engine. The engine has been
motified. I need advice to start a base line on the carb tuning. The
engine has 600 series Andrews Cams, Ported & Polished heads, 45 mm
Mikuni Carb, D&M Spike Air Cleaner, Martin brothers pipes. I will
need to check for intake leaks. The bike has nuts. I pulls nice in
low gears. The problem that I find is that every now and the it pops
or backfires through the carb. Any ideas or help would be great. I
would like an idea of what size main and pilot jets I should start
with. Thanks
MaxHeadflow
If at constant speed try going up on the pilot jet one size. If when you twist the wick, try increasing the accelerator shot or raising the needle/main.
Bruce
1 - 2 of 2 Posts
