Hi Guys,
I am trying to get up-to-speed with regard to tuning my carb for optimum performance. I bought a used 2002 FXDWG TC88 with stage one. As purchased, it was advertised to have the SE Air Filter Kit, Dyno-Jet Carb Kit, and V&H Long Shots.
I'm making a couple of change right off the bat. I am changing the pipes to Vance and Hines Big Shot Staggerds and I'm changing the air filter from the paper SE to the K&N HD-0800.
I want the bike to run 'right' - Not too rich and not too lean and be tuned properly for maximum power.
So, I was thinking of taking it to my local dealer to have it dyno-tuned after these small changes.
I read this marathon read and came away with the notion that the Dyno-Jet kit can be properly tuned and it is flexible with regard to tuning. However, it appears that some tuners tune these way too rich resulting in mpg in the low to mid thirties.
http://65.38.172.84/forums/showthread.php?t=43934&highlight=stage+tuning+jets
The questions:
Looking for guidance...:thanks: :thanks:
Kevin
The questions:
- What is the proper A/F ratio I should look for on the dyno graph
- Does anyone have electronic documentation on this kit that I could read to get more famalier with how to tune the kit?
- What changes are made to the carb during the install of the kit?
- Is there a 'sweet-spot' set-up on the Dyno-Jet kit documented for a Stage 1 bike with SE Air and V&H BSS pipes? If so, then maybe I can by-pass the dyno tune and make the changes to the carb myself.
- Do you think this dyno tune will be value added?
Kevin
